Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Message 1 of 10
527 Views, 9 Replies
Verification
Hello everybody,
I should make the stability verification of a structure. My problem is how to verify the structure after the analysis. I don´t understand for example how to verify or to dimension the reinforcement on a slab. May I have an extension? Or it´s just from slab reinforcement tab?
I´m using Robot structural analysis 2010.
Could you help me? Thank you
9 REPLIES 9
Message 2 of 10
Artur.Kosakowski
Please look at http://forums.autodesk.com/t5/Robot-Structural-Analysis/Tutorials-for-Robot-Structure-analysis/m-p/2... and check the example 8 from the training manual.
Artur Kosakowski
Message 3 of 10
Thank you very much for your help.
I've already followed that example, but it's a concrete slab, so basically the software verify the structure thanks to the reinforcement issues. But if I have a masonry structure without reinforcement the software doesn't do the verification, since (as I see) it is able to verify it just by the reinforcement RC design tabs.
Have you got further informations?
Thanks again 😉
Message 4 of 10
t.sautierr
you can't check a masony wall with robot.
you have to do manual checkings.
the sole thing you can do is to model properly the masonry wall and use the results of efforts
Message 5 of 10
Artur.Kosakowski
There is no module for masonry design in the current version of Robot.
Artur Kosakowski
Message 6 of 10
Yes exactly I noticed! I'm doing the verification manually. The only problem is that the software consider the walls as membrane and a masonry is not reducible to a membrane.
Talking about the results. Do you know exactly the difference between S-stress and N-membrane forces (complex results), because they are both axial stresses, but which of them should be verified? Also there is a huge difference between them in terms of value, N is much bigger.
Message 7 of 10
t.sautierr
Send an image in order we the exactly what you are talking about + send a image of the properties you chose for your pannel
Message 8 of 10
Here you have a synthesis.
Message 9 of 10
t.sautierr
I meant properties of the pannels not the material.
See attached picture.
Results : don't mix stress and forces (force is the integral of stress along a cut, basically stress is a local forces applied to an area very small : F = int ( stress * da) . unit vector.)
See attached docs.
In your case, what is relevant for global design is : reduced results for pannels.
By the way : Robot is not considering your wall as a membrane unless you set either the properties to simulate this behavior eithier you choose the structure type to it.
Message 10 of 10
t.sautierr
in reply to: t.sautierr
Pannels properties
