Discussion Groups
Robot Structural Analysis
*Expert Elite*
111 Kudos
VERIFICATION GROUP MEMBER
294 Views, 12 Replies
09-05-2012 10:26 AM
Hi everyone
i have a little problem, when i analyze the results of member verification with the diagram option (see below)
in the preview version of robot i can isolate a range of "verification group member" grouped on ratio value (for example from 0.2 to 0.6) an create a structure with uniform "ratio" distribution and optimize more efficently everything. In the 2013 version this tool don't work correctly, if i define a range of ratio values, the software don't isolate nothing.
Anyone of you can help me???
Greetings.
PasProStudio
Structural + Detailing engineers
Product Support
760 Kudos
Re: VERIFICATION GROUP MEMBER
09-05-2012 11:46 PM in reply to: StefanoPasquini6790
I' not sure if I understand you correctly but it should be enough to:
Artur Kosakowski
*Expert Elite*
111 Kudos
09-05-2012 11:54 PM in reply to: Artur.Kosakowski
Good morning Artur
as shown in the image of your mail, when i define the limits, lower and upper, are not activated selection filters and the values that writing in the cell of setting are reset to the value 0.
There is something thet i can do to fit this issue?
Greatings and thanks.
PasProStudio
Product Support
760 Kudos
09-06-2012 12:08 AM in reply to: StefanoPasquini6790
Actually this was your picture with my comment on it. I'm  attaching my picture now :smileyhappy:
Artur Kosakowski
*Expert Elite*
111 Kudos
09-06-2012 12:19 AM in reply to: Artur.Kosakowski
Hi Artur and thank for your extreme speed. When i digit the value of upper and lower limit range, automaticly this value is reset to zero. I don't understand, often I used this command to create verification subgroups to refine the optimization of structures...
Spoiler
PasProStudio
Product Support
760 Kudos
09-06-2012 12:30 AM in reply to: StefanoPasquini6790
Try to do this in the following way:
1. Type lower limit and press TAB key
2. Type upper limit and press TAB key
Check if there is any difference if you use comma (0,2) or dot (0.2)
Artur Kosakowski
*Expert Elite*
111 Kudos
09-06-2012 01:41 AM in reply to: Artur.Kosakowski
Hi Artur,
this is exactly the procedure that i usually use to create a sub group, i tried to use "," or ".", but...nothing! The result is always "reset to zero".
I don't understad....
PasProStudio
Product Support
760 Kudos
09-06-2012 01:55 AM in reply to: StefanoPasquini6790
Attach the model please. I'll check if I can find any reason for this.
Artur Kosakowski
*Expert Elite*
111 Kudos
09-06-2012 02:58 AM in reply to: Artur.Kosakowski
this is the file, but it's only an exemple. This problem is in every rtd model...
thk
PasProStudio
Product Support
760 Kudos
09-06-2012 03:24 AM in reply to: StefanoPasquini6790
Try to delete all temporary windows files as well as rename your CfgUsr folder. Start a new project. Is it the same?
Cfgusr
Win XP:
c:\Documents and Settings\username\Application Data\Autodesk\Autodesk Robot Structural Analysis 2013\CfgUsr\
Win Vista:
C:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2013\CfgUsr\
Win 7 32- or 64-bit RSAPro:
As you can I have no such situation after opening your file. You may also try to set the limits graphically./ After activating the field move mouse on the diagram and click to set the value.
Artur Kosakowski
