Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
skilak
184 Views, 2 Replies
-ve tension
Is it posible to change the sign of axial forces and if so where can I change in Robot that the compression is negative and tension positive for bars?
2 REPLIES 2
Artur.Kosakowski
in reply to: skilak
Not possible. All you can do is to display axial forces in the result table in two separate columns (tension and compression).
Artur Kosakowski
skilak
in reply to: Artur.Kosakowski
Then I have something for the wish list.
Cheers,
