VBA loads - API
44 REPLIES 44
Message 1 of 45
mateaus
2332 Views, 44 Replies
VBA loads - API
I create a sub which define loads on a pannel but it's doesn't work.
Can you have a look ?
Public typecharge As String
Public casdecharge As String
Public valeurcharge As Double
Public x_1 As Double
Public y_1 As Double
Public z_1 As Double
Public x_2 As Double
Public y_2 As Double
Public z_2 As Double
Public x_3 As Double
Public y_3 As Double
Public z_3 As Double
Public x_4 As Double
Public y_4 As Double
Public z_4 As Double
Public Sub charges()
'trotoirs
typecharge = I_CN_PERMANENT
casdecharge = "Equipements"
valeurcharge = 5.5
x_1 = 0.000
y_1 = 0.000
z_1 = 0.000
x_2 = 75.480
y_2 = 0.000
z_2 = 0.000
x_3 = 76.143
y_3 = 1.600
z_3 = 0.000
x_4 = 0.663
y_4 = 1.600
z_4 = 0.000
Call chargement_panneau_contour
End Sub
Sub chargement_panneau_contour()
    Dim cas As RobotSimpleCase
    Dim recs As RobotLoadRecordMngr
    Dim rec_1 As RobotLoadRecordInContour
    Set cas = robapp.Project.Structure.Cases.CreateSimple(robapp.Project.Structure.Cases.FreeNumber, _
casdecharge, typecharge, I_CAT_STATIC_LINEAR)
    Set recs = cas.Records
' pression uniforme horizontale appliquée au contour
' définition des contours
    i = recs.New(I_LRT_IN_CONTOUR)
' création d'une nouvel enregistrement
    Set rec_1 = recs.Get(i)
' définition du plan de charge
    rec_1.Objects.FromText "1"
    rec_1.SetValue I_ICRV_PX1, 0
    rec_1.SetValue I_ICRV_PY1, 0
    rec_1.SetValue I_ICRV_PZ1, -valeurcharge
    rec_1.SetValue I_ICRV_PX2, 0#
    rec_1.SetValue I_ICRV_PY2, 0#
    rec_1.SetValue I_ICRV_PZ2, -valeurcharge
    rec_1.SetValue I_ICRV_PX3, 0#
    rec_1.SetValue I_ICRV_PY3, 0#
    rec_1.SetValue I_ICRV_PZ3, -valeurcharge
    ' sens de projection des efforts
    rec_1.SetValue I_ICRV_PROJECTION, 1
    ' nombre de points composant le contour
    rec_1.SetValue I_ICRV_NPOINTS, 4
    rec_1.SetValue I_ICRV_LOCAL, 0
    ' définition des points sur le panneau
    rec_1.SetPoint 1, 0, 0, 0
    rec_1.SetPoint 2, 1, 1, 0
    rec_1.SetPoint 3, 1, 0, 0
    rec_1.SetContourPoint 1, x_1, y_1, z_1
    rec_1.SetContourPoint 2, x_2, y_2, z_2
    rec_1.SetContourPoint 3, x_3, y_3, z_3
    rec_1.SetContourPoint 4, x_4, y_4, z_4
    rec_1.SetVector 0, 0, 1
    Set recs = Nothing
    Set rec_1 = Nothing
    Set cas = Nothing
End Sub
44 REPLIES 44
Message 2 of 45
mateaus
in reply to: mateaus
For the
 rec_1.SetValue I_ICRV_PZ1, valeurcharge * 1000
Problem solved (it's because I had to multiply by 1000)
For the selection of panels
My problem is that it's not a selection automatic (of panels).
I think the command I need it's like
rec_1.Objects.???? 'automatic
Message 3 of 45
Rafal.Gaweda
Some bugs should be corected as shown below :
Public typecharge As Integer
Set RobApp = New RobotApplication    ' or activate somewhere else robotapplication
rec_1.Objects.FromText "30to36"
Rafal Gaweda
Message 4 of 45
Rafal.Gaweda
@mateaus wrote:
For the
Keep in mind - you are using SI units (N,m) in API dirrectly
 only:  rec_1.Objects.FromText "all"
/ if french  robot version used please use french text syntax:     rec_1.Objects.FromText "tous"
ALL selects all objects
Rafal Gaweda
Tags (1)
Message 5 of 45
mateaus
in reply to: Rafal.Gaweda
Ok thank you,
I have 3 combinations number 20 21 22 and I want to have the max and the min of moments :
for example Mxx+ and Myy-
example
What is the code to display it ?
Message 6 of 45
mateaus
up
Message 7 of 45
Rafal.Gaweda
Display on Map or just find  to have it for further use?
Rafal Gaweda
Message 8 of 45
mateaus
Display on map please
Message 9 of 45
Rafal.Gaweda
Unfortunatelly it is not posible to dispplay only max \ min on map thru API
mavueRobot.ParamsFeMap.WithDescription = True  ' this is the only one settings for maps description
Rafal Gaweda
Message 10 of 45
mateaus
Can we select many combinations in the same time and ask for a display of Mxx+ for example ?
It will display the maximum normally ?
Message 11 of 45
Rafal.Gaweda
mavueRobot.Selection.Get(I_OT_CASE).FromText ("101")
write here selection (list) of cases
Rafal Gaweda
Message 12 of 45
mateaus
Is it possible to write this and ask MXX+?
Ps : Can you answer to my message on your private box?
mavueRobot.Selection.Get(I_OT_CASE).FromText ("101 102 103")
Message 13 of 45
Rafal.Gaweda
As a default top envelope is displayed automatically
Answered
Rafal Gaweda
Message 14 of 45
mateaus
I would like to create a load on a line on my slab like :
linear load
I would like the same macro like this one but in order to create a linear load
'définit les cas de charges
Dim Loads As RobotCaseServer
Set Loads = robapp.Project.Structure.Cases
    Set cas = Loads.Get(nocasdecharge)
'creer un nouveau cas :
'    Set cas = robapp.Project.Structure.Cases.CreateSimple(robapp.Project.Structure.Cases.FreeNumber, _
    rec_1.SetValue I_ICRV_PZ1, -valeurcharge * 1000
    rec_1.SetValue I_ICRV_PZ2, -valeurcharge * 1000
    rec_1.SetValue I_ICRV_PZ3, -valeurcharge * 1000
    Set recs = Nothing
    Set rec_1 = Nothing
    Set cas = Nothing
End Sub
 Can you help me ?
Message 15 of 45
Rafal.Gaweda
Adjust this code :
Dim rec_1 As RobotLoadRecordLinear3D
Set cas = robapp.Project.Structure.Cases.CreateSimple(robapp.Project.Structure.Cases.FreeNumber _
, "Case_2", I_CN_PERMANENT, I_CAT_STATIC_LINEAR)
i = recs.New(I_LRT_LINEAR_3D)
rec_1.SetValue I_L3DRV_PX1, 0
rec_1.SetValue I_L3DRV_PY1, 0
rec_1.SetValue I_L3DRV_PZ1, -100
rec_1.SetValue I_L3DRV_MX1, 0
rec_1.SetValue I_L3DRV_MY1, 0
rec_1.SetValue I_L3DRV_MZ1, 0
rec_1.SetValue I_L3DRV_PX2, 0
rec_1.SetValue I_L3DRV_PY2, 0
rec_1.SetValue I_L3DRV_PZ2, 0
rec_1.SetValue I_L3DRV_MX2, 0
rec_1.SetValue I_L3DRV_MY2, 0
rec_1.SetValue I_L3DRV_MZ2, 0
rec_1.SetValue I_L3DRV_LOCAL, 0
rec_1.SetPoint 1, 0.75, 1, 0  ' set coordinates here
rec_1.SetPoint 2, 0.75, 5, 0  ' set coordinates here
Set recs = Nothing
Set rec_1 = Nothing
Set cas = Nothing
Rafal Gaweda
Message 16 of 45
mateaus
Ok great, it's working,
Yet, it's the most difficult load to programm : a convoy
convoi
I think I have a lot of input data like :
define the polyline
the name of convoy
the direction of load
the type of load (uniform surface)
the value of load (P)
the loads geometry (x, y, dx, dy)
and the convoy dimensions
Would you mind give me an example like previous macros ?
Message 17 of 45
Rafal.Gaweda
It is only possible to define Symmetric Vehicel using API.
Are you still interested ?
Some example code how to define vehicle attached
-          Define vehicles as many as you want with as many records as you want in the same way as shown in attached xls (one below another)
These texts should be used in column C : Vehicle name, linear load, concentrated force, surface load
Rafal Gaweda
Message 18 of 45
mateaus
Yes still interested,
For my example the loads are not symmetric. Maybe we can use a convoy saved in a catalog by myself ? But I don't know how to call the saved convoy in a catalog by API ?
Any solution ?
Message 19 of 45
Rafal.Gaweda
Creating moving load case with vehicle loaded from database:
Dim Cas As RobotMobileCase
Dim Route As RobotMobileCaseRoute
Dim VData As RobotVehicleData
 ' route is a polyline  - creating polyline here
Dim PlineGeometry As RobotGeoPolyline
Set PlineGeometry = Robapp.CmpntFactory.Create(I_CT_GEO_POLYLINE)
Dim Segment As RobotGeoSegment
Dim Object As RobotObjObject
 ' create as many segments (= characteristic points of polyline) as you like in the way shown below
Set Segment = Robapp.CmpntFactory.Create(I_CT_GEO_SEGMENT_LINE)
Segment.P1.Set 0, 2, 0
PlineGeometry.Add Segment
PlineGeometry.Initialize
Segment.P1.Set 10, 2, 0
RouteNumber = 13
 ' creating object from polyline
Set Object = Robapp.Project.Structure.Objects.Create(RouteNumber)
Object.Main.Geometry = PlineGeometry
Object.Initialize
Object.Update
 ' creating moving load case
Set Cas = Robapp.Project.Structure.Cases.CreateMobile(Robapp.Project.Structure.Cases.FreeNumber, "Moving Load Case", I_CN_PERMANENT)
 ' assigning route and route parameters to case
Set Route = Cas.GetRoute
Route.Geometry = RouteNumber
Dim Fac As RobotMobileCaseSegmentFactors
Set Fac = Route.GetFactors(1)
Fac.VL = 1
Fac.VR = 1
Route.SetFactors 1, Fac
Route.LoadDirection.Set 0, 0, -1
Route.Step = 1
Cas.SetRoute Route
 ' assign vehicle to case
Set VLabel = Robapp.Project.Structure.Labels.Create(I_LT_VEHICLE, "Pojazd S - klasa E") ' select vehicle name
Set VData = VLabel.Data
VData.LoadFromDBase "Pojazd S - klasa E", "PN1030"  ' select vehicle name and database name
Robapp.Project.Structure.Labels.Store VLabel
Cas.Vehicle = "Pojazd S - klasa E" ' assign vehicle to case
Rafal Gaweda
Message 20 of 45
mateaus
I have created a convoy which name is "TS".
If I understand your macro, I just have to replace "PN1030" by "TS" :
VData.LoadFromDBase "Pojazd S - klasa E", "TS"
I have created a catalog to save my convoy. I don't know how to save it otherwise.
catalog
Will it working with your macro ?
I have an annex question :
I would like to create a convoy's library in order to share it whith my colleagues but I don't know where it is save in the computer and what I have to copy in their computer.
