I create a sub which define loads on a pannel but it's doesn't work.
Can you have a look ?
Public typecharge As String Public casdecharge As String Public valeurcharge As Double Public x_1 As Double Public y_1 As Double Public z_1 As Double Public x_2 As Double Public y_2 As Double Public z_2 As Double Public x_3 As Double Public y_3 As Double Public z_3 As Double Public x_4 As Double Public y_4 As Double Public z_4 As Double
Public Sub charges() 'trotoirs typecharge = I_CN_PERMANENT casdecharge = "Equipements" valeurcharge = 5.5 x_1 = 0.000 y_1 = 0.000 z_1 = 0.000 x_2 = 75.480 y_2 = 0.000 z_2 = 0.000 x_3 = 76.143 y_3 = 1.600 z_3 = 0.000 x_4 = 0.663 y_4 = 1.600 z_4 = 0.000 Call chargement_panneau_contour End Sub
Sub chargement_panneau_contour() Dim cas As RobotSimpleCase Dim recs As RobotLoadRecordMngr Dim rec_1 As RobotLoadRecordInContour Set cas = robapp.Project.Structure.Cases.CreateSimple(robapp.Project.Structure.Cases.FreeNumber, _ casdecharge, typecharge, I_CAT_STATIC_LINEAR) Set recs = cas.Records ' pression uniforme horizontale appliquée au contour ' définition des contours i = recs.New(I_LRT_IN_CONTOUR) ' création d'une nouvel enregistrement Set rec_1 = recs.Get(i) ' définition du plan de charge rec_1.Objects.FromText "1" rec_1.SetValue I_ICRV_PX1, 0 rec_1.SetValue I_ICRV_PY1, 0 rec_1.SetValue I_ICRV_PZ1, -valeurcharge rec_1.SetValue I_ICRV_PX2, 0# rec_1.SetValue I_ICRV_PY2, 0# rec_1.SetValue I_ICRV_PZ2, -valeurcharge rec_1.SetValue I_ICRV_PX3, 0# rec_1.SetValue I_ICRV_PY3, 0# rec_1.SetValue I_ICRV_PZ3, -valeurcharge ' sens de projection des efforts rec_1.SetValue I_ICRV_PROJECTION, 1 ' nombre de points composant le contour rec_1.SetValue I_ICRV_NPOINTS, 4 rec_1.SetValue I_ICRV_LOCAL, 0 ' définition des points sur le panneau rec_1.SetPoint 1, 0, 0, 0 rec_1.SetPoint 2, 1, 1, 0 rec_1.SetPoint 3, 1, 0, 0 rec_1.SetContourPoint 1, x_1, y_1, z_1 rec_1.SetContourPoint 2, x_2, y_2, z_2 rec_1.SetContourPoint 3, x_3, y_3, z_3 rec_1.SetContourPoint 4, x_4, y_4, z_4 rec_1.SetVector 0, 0, 1 Set recs = Nothing Set rec_1 = Nothing Set cas = Nothing End Sub
Solved by Rafal.Gaweda. Go to Solution.
For the
rec_1.SetValue I_ICRV_PZ1, valeurcharge * 1000
Problem solved (it's because I had to multiply by 1000)
For the selection of panels
My problem is that it's not a selection automatic (of panels).
I think the command I need it's like
rec_1.Objects.???? 'automatic
Some bugs should be corected as shown below :
Public typecharge As Integer
Set RobApp = New RobotApplication ' or activate somewhere else robotapplication
rec_1.Objects.FromText "30to36"
@mateaus wrote:
For the
rec_1.SetValue I_ICRV_PZ1, valeurcharge * 1000Problem solved (it's because I had to multiply by 1000)
Keep in mind - you are using SI units (N,m) in API dirrectly
only: rec_1.Objects.FromText "all"
/ if french robot version used please use french text syntax: rec_1.Objects.FromText "tous"
ALL selects all objects
Unfortunatelly it is not posible to dispplay only max \ min on map thru API
mavueRobot.ParamsFeMap.WithDescription = True ' this is the only one settings for maps description
Can we select many combinations in the same time and ask for a display of Mxx+ for example ?
It will display the maximum normally ?
mavueRobot.Selection.Get(I_OT_CASE).FromText ("101")
write here selection (list) of cases
Is it possible to write this and ask MXX+?
Ps : Can you answer to my message on your private box?
mavueRobot.Selection.Get(I_OT_CASE).FromText ("101 102 103")
As a default top envelope is displayed automatically
Answered
I would like to create a load on a line on my slab like :
I would like the same macro like this one but in order to create a linear load
Sub chargement_panneau_contour() 'définit les cas de charges Dim Loads As RobotCaseServer Set Loads = robapp.Project.Structure.Cases Dim cas As RobotSimpleCase Dim recs As RobotLoadRecordMngr Dim rec_1 As RobotLoadRecordInContour Set cas = Loads.Get(nocasdecharge) 'creer un nouveau cas : ' Set cas = robapp.Project.Structure.Cases.CreateSimple(robapp.Project.Structure.Cases.FreeNumber, _ casdecharge, typecharge, I_CAT_STATIC_LINEAR) Set recs = cas.Records ' pression uniforme horizontale appliquée au contour ' définition des contours i = recs.New(I_LRT_IN_CONTOUR) ' création d'une nouvel enregistrement Set rec_1 = recs.Get(i) ' définition du plan de charge rec_1.Objects.FromText "tous" rec_1.SetValue I_ICRV_PX1, 0 rec_1.SetValue I_ICRV_PY1, 0 rec_1.SetValue I_ICRV_PZ1, -valeurcharge * 1000 rec_1.SetValue I_ICRV_PX2, 0# rec_1.SetValue I_ICRV_PY2, 0# rec_1.SetValue I_ICRV_PZ2, -valeurcharge * 1000 rec_1.SetValue I_ICRV_PX3, 0# rec_1.SetValue I_ICRV_PY3, 0# rec_1.SetValue I_ICRV_PZ3, -valeurcharge * 1000 ' sens de projection des efforts rec_1.SetValue I_ICRV_PROJECTION, 1 ' nombre de points composant le contour rec_1.SetValue I_ICRV_NPOINTS, 4 rec_1.SetValue I_ICRV_LOCAL, 0 ' définition des points sur le panneau rec_1.SetPoint 1, 0, 0, 0 rec_1.SetPoint 2, 1, 1, 0 rec_1.SetPoint 3, 1, 0, 0 rec_1.SetContourPoint 1, x_1, y_1, z_1 rec_1.SetContourPoint 2, x_2, y_2, z_2 rec_1.SetContourPoint 3, x_3, y_3, z_3 rec_1.SetContourPoint 4, x_4, y_4, z_4 rec_1.SetVector 0, 0, 1 Set recs = Nothing Set rec_1 = Nothing Set cas = Nothing End Sub
Can you help me ?
Adjust this code :
Dim rec_1 As RobotLoadRecordLinear3D
Set cas = robapp.Project.Structure.Cases.CreateSimple(robapp.Project.Structure.Cases.FreeNumber _
, "Case_2", I_CN_PERMANENT, I_CAT_STATIC_LINEAR)
i = recs.New(I_LRT_LINEAR_3D)
rec_1.SetValue I_L3DRV_PX1, 0
rec_1.SetValue I_L3DRV_PY1, 0
rec_1.SetValue I_L3DRV_PZ1, -100
rec_1.SetValue I_L3DRV_MX1, 0
rec_1.SetValue I_L3DRV_MY1, 0
rec_1.SetValue I_L3DRV_MZ1, 0
rec_1.SetValue I_L3DRV_PX2, 0
rec_1.SetValue I_L3DRV_PY2, 0
rec_1.SetValue I_L3DRV_PZ2, 0
rec_1.SetValue I_L3DRV_MX2, 0
rec_1.SetValue I_L3DRV_MY2, 0
rec_1.SetValue I_L3DRV_MZ2, 0
rec_1.SetValue I_L3DRV_LOCAL, 0
rec_1.SetPoint 1, 0.75, 1, 0 ' set coordinates here
rec_1.SetPoint 2, 0.75, 5, 0 ' set coordinates here
Set recs = Nothing
Set rec_1 = Nothing
Set cas = Nothing
Ok great, it's working,
Yet, it's the most difficult load to programm : a convoy
I think I have a lot of input data like :
define the polyline
the name of convoy
the direction of load
the type of load (uniform surface)
the value of load (P)
the loads geometry (x, y, dx, dy)
and the convoy dimensions
Would you mind give me an example like previous macros ?
It is only possible to define Symmetric Vehicel using API.
Are you still interested ?
Some example code how to define vehicle attached
- Define vehicles as many as you want with as many records as you want in the same way as shown in attached xls (one below another)
These texts should be used in column C : Vehicle name, linear load, concentrated force, surface load
Yes still interested,
For my example the loads are not symmetric. Maybe we can use a convoy saved in a catalog by myself ? But I don't know how to call the saved convoy in a catalog by API ?
Any solution ?
Creating moving load case with vehicle loaded from database:
Dim Cas As RobotMobileCase
Dim Route As RobotMobileCaseRoute
Dim VData As RobotVehicleData
' route is a polyline - creating polyline here
Dim PlineGeometry As RobotGeoPolyline
Set PlineGeometry = Robapp.CmpntFactory.Create(I_CT_GEO_POLYLINE)
Dim Segment As RobotGeoSegment
Dim Object As RobotObjObject
' create as many segments (= characteristic points of polyline) as you like in the way shown below
Set Segment = Robapp.CmpntFactory.Create(I_CT_GEO_SEGMENT_LINE)
Segment.P1.Set 0, 2, 0
PlineGeometry.Add Segment
PlineGeometry.Initialize
Segment.P1.Set 10, 2, 0
RouteNumber = 13
' creating object from polyline
Set Object = Robapp.Project.Structure.Objects.Create(RouteNumber)
Object.Main.Geometry = PlineGeometry
Object.Initialize
Object.Update
' creating moving load case
Set Cas = Robapp.Project.Structure.Cases.CreateMobile(Robapp.Project.Structure.Cases.FreeNumber, "Moving Load Case", I_CN_PERMANENT)
' assigning route and route parameters to case
Set Route = Cas.GetRoute
Route.Geometry = RouteNumber
Dim Fac As RobotMobileCaseSegmentFactors
Set Fac = Route.GetFactors(1)
Fac.VL = 1
Fac.VR = 1
Route.SetFactors 1, Fac
Route.LoadDirection.Set 0, 0, -1
Route.Step = 1
Cas.SetRoute Route
' assign vehicle to case
Set VLabel = Robapp.Project.Structure.Labels.Create(I_LT_VEHICLE, "Pojazd S - klasa E") ' select vehicle name
Set VData = VLabel.Data
VData.LoadFromDBase "Pojazd S - klasa E", "PN1030" ' select vehicle name and database name
Robapp.Project.Structure.Labels.Store VLabel
Cas.Vehicle = "Pojazd S - klasa E" ' assign vehicle to case
I have created a convoy which name is "TS".
If I understand your macro, I just have to replace "PN1030" by "TS" :
VData.LoadFromDBase "Pojazd S - klasa E", "TS"
I have created a catalog to save my convoy. I don't know how to save it otherwise.
Will it working with your macro ?
I have an annex question :
I would like to create a convoy's library in order to share it whith my colleagues but I don't know where it is save in the computer and what I have to copy in their computer.
