We are currently using RSAP for modelling underground Structures for a metro project in the middle east:
See Image below for example of what we are doing:
As you can see, we have stations that varies from section to section.
We are having difficulty with knowing what is the best soil spring to be applied since we have varying support widths.
My question is, does robot have a function where we can encode multiple types of soil supports for a single thickness on a single robot model??
If I understand you correctly the solution would be to define separate panels for the areas where you have different values of KZ and assign corresponding thickness labels to them. Otherwise you can define elastic nodal supports with different KZ values but IMHO that would be not that easy as you would have to freeze meshes and consider the tributary area for each of the nodes.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
@Artur.Kosakowski wrote:If I understand you correctly the solution would be to define separate panels for the areas where you have different values of KZ and assign corresponding thickness labels to them. Otherwise you can define elastic nodal supports with different KZ values but IMHO that would be not that easy as you would have to freeze meshes and consider the tributary area for each of the nodes.
Yes. that is the work around that we are doing. which makes us use two models running at the same time with different soil modulus on it. then compare it manually side by side for force extraction used for design.
I was hoping that there is an option within robot so that we can just envelope the load cases to have a unified result for easier force extraction. 😞
I'm not sure if I understand all this situation correctly but if the only change is the KZ parameters assigned to the panel thickness label then you can use the phased structures option and get the access to both set of results in a single file. Mind to freeze the meshes before creating the phases.
