I would like to know how can I vary my section height. Suppose I have an IPE100 (I-beam) with 2 meters length. I want it to start with 100 mm height and end with 50 mm height. When I use variable section it varies both flanges equal, so in the end the top flange is not horizontal. I would like to know how can I vary only my bottom flange and keep the top flange horizontal (with the same z coordinate along 2 meters).
Hope you can help me,
Thank you very much,
Pedro
Solved by dimogrec. Go to Solution.
