Robot Structural Analysis Forum
Welcome to Autodeskā€™s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Showing results forĀ
Did you mean:Ā
Values of the diagrams (Mx,My,Mz)
4 REPLIES 4
2690 Views, 4 Replies
Please tell me why I can't see the values of these moments in the end and at the beginning of the rods? (for example for the rod 2084) Thanks in advance 1.jpg
4 REPLIES 4
tony.ridley
You probably have "global extremes" checked.  Change to "all"
(under results--------->diagrams for bars-------->parameters)
in reply to: tony.ridley
What do I do wrong?
Artur.Kosakowski
Please use maps on bars descriptions instead. The description for diagrams show max and min values only.
Artur Kosakowski
Yes this is true.
But only when the element has "symetrical" internal forces, such as in the original picture posted.  Of course if the loading is constant the end moment will be the same at both ends,
If the force in the bar is not symetrical, then my suggestion worksSmiley Very Happy.
