Discussion Groups
Robot Structural Analysis
faisal.aaouatif
Using the French kit RSA expert
680 Views, 13 Replies
10-28-2013 08:58 AM
Unable to use (install ok ) the french_country_kit_for_autodesk_robot_structural_analysis_expert_2012_2 even if im on RSA2014...
see attachement
Help needed please.
Please use plain text.
Product Support
Artur.Kosakowski
Re: Using the French kit RSA expert
10-30-2013 12:43 AM in reply to: faisal.aaouatif
You missed the attachment.
Is that that you have Robot 2014, Robot 2012 and Robot Expert 2012 installed  and you can work with Robot 2014, Robot 2012 but not Expert 2012?
Artur Kosakowski
faisal.aaouatif
10-30-2013 01:16 AM in reply to: Artur.Kosakowski
sorry ;
it seems that i cannot add attachement ??.
anyway Products in this machine :
RSA 2013 and  2014 installed and worked
CBS 2013 and CBS 2014 installed and worked
Spreadsheet Calculator 2013 installed and worked
Spreadsheet Calculator 2014 installed but only get blank page at openning ( 33sheet11 )
Expert 2012 installed but not working on full mode ( only demo )
System XP Professionnal 64 bit.
Thank you
Product Support
Artur.Kosakowski
10-30-2013 02:17 AM in reply to: faisal.aaouatif
Try to zip it.
Have you downloaded and installed the Content from the Subscription site?
You should receive a separate message for  this topic. Please let me know if the solution I proposed worked for you.
Mind that XP is no loner officially supported for v.2014
Artur Kosakowski
faisal.aaouatif
10-30-2013 08:26 AM in reply to: Artur.Kosakowski
Thank you Artur ,
The reinstallation of the French Kit by the .msi afforded solved the problem :smileyhappy:.
Is there a solution for Spread sheet calculator 2014 ?
What is the recommeded system for Autodesk Products ( Premium Building suite 2014, RSA2014 ) ?
Thank you
Product Support
Artur.Kosakowski
10-31-2013 01:49 AM in reply to: faisal.aaouatif
To be honest based on the description you provided I'm not sure what the actual situation is. Are you able to open and use one of the provided modules selection it from the tree? Mind that the content of SC2014 is in fact the same as SC2013.
Follow the recommendations for Revit. Robot is less demanding :smileyhappy:
Artur Kosakowski
faisal.aaouatif
10-31-2013 03:22 AM in reply to: Artur.Kosakowski
Good Morning / Evening Artur
This point was that there is only a blank worksheet loaded, with no tree of modules.
I Have just reinstalled the product and things got Ok.
Thank you very much
faisal.aaouatif
01-29-2014 11:05 AM in reply to: Artur.Kosakowski
Hi Artur ,
ive upgraded my machine from XP64 to Win7 64 , but when i downloaded the Expert module from my subscription account and install it successfully ,  it dosent work.
thanks for help.
Product Support
Artur.Kosakowski
01-30-2014 12:43 AM in reply to: faisal.aaouatif
Is there any message displayed?
Artur Kosakowski
faisal.aaouatif
01-30-2014 03:25 AM in reply to: Artur.Kosakowski
Hi Artur
See attachment please.
Thank you
