Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
User reinforcing database and required reinforcment
6 REPLIES 6
Romanich
450 Views, 6 Replies
I made my own database of reinforcement bars and when used it I see this:
As I know from SDK Kit, Robot uses method to obtain diameter from area of required reinforcement. So, question is - maybe uses of BarSize field data (or DiameterReal) will be correct than this one ?
In provided reinforcement all correct.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
6 REPLIES 6
Artur.Kosakowski
in reply to: Romanich
I'm not sure if I understand you correctly. Is the objective to have 2f14.8 and 4f23.2 in the reinforcement table?
Artur Kosakowski
Romanich
in reply to: Artur.Kosakowski
No, objective is to have 2f16 and 4f25 in the reinforcement table.
Roman Zhelezniak
Romanich
Artur, for example, I've used non metric ACI RC code and ACI reinforcing database:
Roman Zhelezniak
Artur.Kosakowski
I'm sorry but the currently the values displayed in these fields are generated with use of the different tool and not taken from the indicated field of the bar database.
Artur Kosakowski
Romanich
Can you add this issue to Wishlist?
Roman Zhelezniak
Artur.Kosakowski
I have already done this. I always do Smiley Happy
Artur Kosakowski
