I made my own database of reinforcement bars and when used it I see this:
As I know from SDK Kit, Robot uses method to obtain diameter from area of required reinforcement. So, question is - maybe uses of BarSize field data (or DiameterReal) will be correct than this one ?
In provided reinforcement all correct.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Solved by Artur.Kosakowski. Go to Solution.
I'm not sure if I understand you correctly. Is the objective to have 2f14.8 and 4f23.2 in the reinforcement table?
No, objective is to have 2f16 and 4f25 in the reinforcement table.
Roman Zhelezniak
Artur, for example, I've used non metric ACI RC code and ACI reinforcing database:
Roman Zhelezniak
I'm sorry but the currently the values displayed in these fields are generated with use of the different tool and not taken from the indicated field of the bar database.
Can you add this issue to Wishlist?
Roman Zhelezniak
