Discussion Groups
Robot Structural Analysis
Distinguished Contributor
bjur
User defined shape directory
125 Views, 1 Replies
01-08-2013 10:41 AM
Where is the user defined shape directory?  Also, after I define a custom shape, how can I save it so that I can edit it again.  Robot won't let me edit the .sec file I saved the custom shapes to.
Please use plain text.
Product Support
Artur.Kosakowski
Re: User defined shape directory
01-09-2013 12:11 AM in reply to: bjur
Win XP:
c:\Documents and Settings\username\Application Data\Autodesk\Structural\Common Data\2013\
Win Vista:
C:\Users\username\AppData\Roaming\Autodesk\Structural\Common Data\2013\
Win 7 32- or 64-bit RSAPro:
You can edit the section in the Section Builder module after opening it from the selected database:
To open *.sec file use:
Artur Kosakowski
