What is easiest method to create attached section in the Robot?
Solved by Rafacascudo. Go to Solution.
Solved by mpaknia. Go to Solution.
you can
1-save this dwg as dwf and import it into section definition module.
or
2-Import the I section from any of the available profile databases , then add the lateral plates and make it "united" clicking on menu Contour/ standardization of overlapped contours
or
3- Build it from scratch if I section is not in any of the databases
All 3 options using the section definition module
Rafael Medeiros
Rafael Medeiros
Rafael Medeiros
Well, I saved your dwg as 2013 dxf , imported it (fixed angle=4).
Then select the contours that are supposed to be openings , right click / properties , mark "openings" , apply. See below
Rafael Medeiros
You can type anything on all 3 dimensions ,or only on dimensions 1 and 3.
I would select " box" for this section type , so it can be verified by the standard you choose.
Rafael Medeiros
