Discussion Groups
Robot Structural Analysis
Valued Mentor
58 Kudos
User Defined Section
171 Views, 3 Replies
06-13-2012 07:38 AM
I was wondering what code to use to design user defined sections. I need this for composite beam while entering them as user defined members. Thanks in advance.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Product Support
1,305 Kudos
Re: User Defined Section
06-13-2012 07:43 AM in reply to: AJA14
Do you mean section shape?
I guess most similar to the way (section symbol = way of design in case of steel mamber) you would do it in reality.
(BTW: there is no code for composite design in Robot)
Rafal Gaweda
Valued Mentor
58 Kudos
06-14-2012 01:13 AM in reply to: AJA14
I think my question was misunderstood. I am inserting my members as user defined sections. when I run the calculations for the member verification according to AISC I don't get any ratios. I think Robot does not design user defined members as per AISC. I was wondering if there was another code I could use to design these members such as EN or BS.
Ali Al-Hammoud
Product Support
1,305 Kudos
06-14-2012 01:41 AM in reply to: AJA14
Send me example file + your section database
My example below:
section RG 1 - SHAPE_TYPE=0
section RG 2 - SHAPE_TYPE=10
section COMP 1 - SHAPE_TYPE=10, containing parts with different steel materials
Rafal Gaweda
