Hi I have been utilizing a previous colleagues program and thoroughly checking everything. However I am unable to view the user profile of custom made beams. I am only able to see some details if I look at the details but otherwise I cant find anything. opening the new section folder I am able to see the bar type, double clicking on it reveals no information for me, if I look in section database I cant open the user database. the file was created in 2012, any help is appreciated.
Regards
Solved by Artur.Kosakowski. Go to Solution.
Do you have it (xml file)?
In such case you will not be able to see the exact definition of a profile unless you have the ruserpro.xml sent. What information are you interested in? Some,such as e.g. Ax, IY or IZ are accessible in the bars or properties table.
Well its neccesary to visually check the profile. eg Does robot show the correct sections on the structural view? Personally dont think the tables are adequate, I feel if a custom profile is created it should be saved with the model.
The xml is not saved with a model. By default it is located in C:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis version number\CfgUsr folder.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
