Discussion Groups
Robot Structural Analysis
Product Support
Rafal.Gaweda
useful addins for Robot (API)
7765 Views, 0 Replies
04-30-2013 07:41 AM
API Tutorial
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-Tutorial/td-p/3939601
Rounding up / down coordinates addin
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Rounding-up-coordinates-API/td-p/3430533/pag...
Ordinary round coordinates addin
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Error-message-API/m-p/3878461/highlight/true...
Macros for contour points modification and rounding
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/VBA-Excel-macro-for-any-object-geometry-modi...
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/panel-co-ordinates/td-p/3168358/highlight/tr...
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Panel-contour-points-modification-API/td-p/3...
Macro for correcting nodes position by defining the path
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-macro-for-correcting-nodes-position-by-d...
Macro for weeding \ removing intermediate points of panels
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Addin-Weeding-remove-intermediate-points-for...
Addin for intersection panels with each other
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Addin-for-intersection-panels-with-each-...
Addin for intersection/extension bars to plane
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Addin-for-intersection-extension-bars-to...
Merging bars addin
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-addin-for-merging-two-bars-into-one/td-p...
Addin checking flatness of panels, contours, claddings
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-addin-checking-flatness-of-panels-contou...
objects geometry to triangles converter
 http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-objects-geometry-to-triangles-converter/...
macro for converting panels to claddings
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-macro-for-converting-panels-to-claddings...
Bars to Lines Converter addin
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Bars-to-Lines-Converter-addin/td-p/49225...
Macro for Stories levels correction
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-VBA-Excel-for-stories-levels-modificatio...
Macro for geting and creating cartesian set of structural axes
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-macro-for-geting-and-creating-cartesian-...
Macro for highlighting nodes with instabilities
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-macro-for-highlighting-nodes-with-instab...
 Addin and macro for detecting short calculation elements
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-addin-for-short-calculation-elements-det...
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-macro-for-detecting-short-calculation-el...
addin for applying brackets on both sides of bars
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-addin-for-applying-brackets-on-both-side...
addin for creating closest nodes between bars
 http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-addin-for-creating-clossest-nodes-betwee...
Contourize is an add-on for Autodesk Robot that converts panel objects generated by the Extrude tool into normal contour panels.
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Robot-add-on-Contourize-API/m-p/3358865/high...
Addin Bars Under The Curtain Walls
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Bars-Under-The-Curtain-Walls/td-p/460737...
bars to rigid links converter
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Bars-to-links-API/m-p/3743220/highlight/true...
Macro for replacing compatibilities existing in model for new one
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Macro-for-replacing-compatibilities-exis...
Addin: Walls To Loads
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Addin-Walls-To-Loads/td-p/4684075
Macro for creating superbars \ supermembers in Excel table
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Macro-for-creating-superbars-supermember...
different manual combination table,
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Editing-load-cases-in-excel-API/td-p/3320573...
macro with inceremental buckling combination
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-Buckling-combination/td-p/4331271
Converting nodal elastic support generated from planar support onto nodal support
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Editing-nodal-spring-values-API/td-p/3901799
Addin for changing bar forces with node generated load onto no node load.
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-Addin-for-changing-bar-forces-with-node-...
Addin for coping loads for Load Cases
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Addin-for-coping-loads-for-Load-Cases/td...
Macro - linear load converter to line load
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Generation-of-calculation-model-takes-foreve...
Macro converting nodal loads onto force in point loads (for claddings, panels)
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-macro-converting-nodal-loads-onto-force-...
Macro for updating panel contour loads
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-macro-for-updating-panel-contour-loads-f...
Envelope of forces at a connection,
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Envelope-of-forces-at-a-connection-API/m-p/3...
Macro for updating model geometry considering deformation of selected case
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Deformed-geometry-update/m-p/4905994#M22...
macro for nodal displacements in local coordinate system of bars
 http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-macro-for-nodal-displacements-in-local-c...
macro for bar end forces as reactions
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Local-reactions-API/td-p/3791474/page/2
different bars forces tables
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/getting-internal-forces-from-RSA-to-XL-API/t...
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Extract-Envelope-Values-with-API/m-p/3413063...
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-macro-for-max-moment/td-p/4762433
panels results tables
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Export-results-ARSA-via-API/td-p/3294083/hig...
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/RESULTS-EXPORT-VBA-API/td-p/4337588
sum of reactions for the slab on elastic ground
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-sum-of-reactions-for-the-slab-on-elastic...
Import of reactions to new model
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Only-reaction-for-new-model-API/m-p/3659242/...
Nodes rotation – local axes
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Nodes-Rotations-Local-Axes-API/m-p/3459442/h...
THA results to Excel
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Automatic-Nodal-Output-API-THA-results/m-p/3...
FRF results to Excel
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-Exporting-modal-harmonic-load-case-getti...
Rafal Gaweda
Please use plain text.
