Solved by Artur.Kosakowski. Go to Solution.
Considering the fact that you use these sections in your daily work I would create a copy of the US section database, change its name (both the database name and the file itself) and then using Robot section database browser I would rename the sections but you can change the name of a section label as well as shown on the attached picture.
Soo there is no chance of having a Metric Database for any Steel Profiles other than making this?
Don´t need to do that.
Just use the canadian profiles database(CISC) . It´s on metric units and profiles have the same brazilian nomenclature!!!
Rafael Medeiros
