Hello everyone,
i am just beginning to learn about this software. i have a question regarding the drawing of the basement walls.
i am importing the architectural drawing from Autocad and drawing over it. please check the attached picture and tell me if i should draw them like the left or right one. the white lines represent what I want to draw on Robot.
i hope my question is clear and thanks for your help 🙂
thank you so much for your earlier reply. please be kind to look at this attachment and also tell me which drawing is correct if I have a column at the corner between the two shear walls. thank youuuu
You should define the column node at the intersection of the white lines that represent walls.
