Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Uplift Elimination
4 REPLIES 4
MohammadZaman
863 Views, 4 Replies
Uplift Elimination
Hi,Dear.
I want to eliminate uplift force, but when I have seismic forces I can't define nonlinear case.
What can I do now? I have attached robot file and screen shots.
Could you please help me?
Thank you.
4 REPLIES 4
Please check:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/problem-de-convergence-analyse-de-semelle/m-...
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Uplift/m-p/3320823/
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Barre-de-treillis-traction-compression-vs-s%...
Artur Kosakowski
Hello.
But I used equivalent lateral force so there isn't need to use modal analysis and modal results combination.
Seismic force in this way is constant and I defined it manually.
I think it's one of disadvantages of robot.
Is there any option to solve nonlinear calculations (not nonlinear analysis) with equivalent lateral seismic force?
Thank you.
You are correct yet due to some restrictions in Robot internal architecture this is currently not possible. We have this in mind for the next releases.
See http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Equivalent-static-analysis/td-p/3632154
Artur Kosakowski
Introduced in SP4 for Robot 2103. Please check for the availability of this update at the beginning of the next week.
Artur Kosakowski
