Discussion Groups
Robot Structural Analysis
Valued Contributor
0 Kudos
Uplift Elimination
334 Views, 4 Replies
12-31-2012 07:26 AM
Hi,Dear.
I want to eliminate uplift force, but when I have seismic forces I can't define nonlinear case.
What can I do now? I have attached robot file and screen shots.
Could you please help me?
Thank you.
Product Support
759 Kudos
Re: Uplift Elimination
01-02-2013 01:02 AM in reply to: MohammadZaman
Please check:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/problem-de-convergence-analyse-de-semelle/m-...
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Uplift/m-p/3320823/
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Barre-de-treillis-traction-compression-vs-s%...
Artur Kosakowski
Valued Contributor
0 Kudos
01-02-2013 10:06 AM in reply to: Artur.Kosakowski
Hello.
But I used equivalent lateral force so there isn't need to use modal analysis and modal results combination.
Seismic force in this way is constant and I defined it manually.
I think it's one of disadvantages of robot.
Is there any option to solve nonlinear calculations (not nonlinear analysis) with equivalent lateral seismic force?
Thank you.
Product Support
759 Kudos
01-03-2013 02:01 AM in reply to: MohammadZaman
You are correct yet due to some restrictions in Robot internal architecture this is currently not possible. We have this in mind for the next releases.
See http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Equivalent-static-analysis/td-p/3632154
Artur Kosakowski
Product Support
759 Kudos
03-27-2013 06:47 AM in reply to: Artur.Kosakowski
Introduced in SP4 for Robot 2103. Please check for the availability of this update at the beginning of the next week.
Artur Kosakowski
