"If you mean to export reinforcement distribution generated in Robot for selected panels (slabs) to Revit then this is not possible. On the other hand you can export it to ASD Reinforcement and generated dwg drawings there which you can link with the Revit model."
As explained in the topic I provided the link to you cannot 'export' reinforcement bars or wire fabrics from ASD to Revit slab yet you can generate dwg drawing that illustrates this distribution.
So, there is no way to include any slab reinforcement in Revit schedules?
Or placing manually is the only solution?
@Artur.Kosakowski wrote:"If you mean to export reinforcement distribution generated in Robot for selected panels (slabs) to Revit then this is not possible. On the other hand you can export it to ASD Reinforcement and generated dwg drawings there which you can link with the Revit model."
Currently there is no automatic transfer of distribution of reinforcement bars or wire fabrics generated in Robot to Revit.
