Discussion Groups
Robot Structural Analysis
Active Member
0 Kudos
Update reinforcement for slab
211 Views, 3 Replies
07-27-2012 07:19 AM
Could u help me, how I can do the update slab using ASD file ????
 regard
Product Support
760 Kudos
Re: Update reinforcement for slab
07-27-2012 07:46 AM in reply to: mazennazzal
"If you mean to export reinforcement distribution generated in Robot for selected panels (slabs) to Revit then this is not possible. On the other hand you can export it to ASD Reinforcement and generated dwg drawings there which you can link with the Revit model."
As explained in the topic I provided the link to you cannot 'export' reinforcement bars or wire fabrics from ASD to Revit slab yet you can generate dwg drawing that illustrates this distribution.
Artur Kosakowski
Member
0 Kudos
07-24-2014 01:39 AM in reply to: Artur.Kosakowski
So, there is no way to include any slab reinforcement in Revit schedules?
Or placing manually is the only solution?
Product Support
760 Kudos
07-24-2014 01:58 AM in reply to: alexturbo_
Currently there is no automatic transfer of distribution of reinforcement bars or wire fabrics generated in Robot to Revit.
Artur Kosakowski
