Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Update reinforcement for slab
3 REPLIES 3
444 Views, 3 Replies
Could u help me, how I can do the update slab using ASD file ????
 regard
3 REPLIES 3
Artur.Kosakowski
"If you mean to export reinforcement distribution generated in Robot for selected panels (slabs) to Revit then this is not possible. On the other hand you can export it to ASD Reinforcement and generated dwg drawings there which you can link with the Revit model."
As explained in the topic I provided the link to you cannot 'export' reinforcement bars or wire fabrics from ASD to Revit slab yet you can generate dwg drawing that illustrates this distribution.
Artur Kosakowski
in reply to: Artur.Kosakowski
So, there is no way to include any slab reinforcement in Revit schedules?
Or placing manually is the only solution?
Artur.Kosakowski
Currently there is no automatic transfer of distribution of reinforcement bars or wire fabrics generated in Robot to Revit.
Artur Kosakowski
