Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
unintended circular mesh pattern
2 REPLIES 2
SerhanB
455 Views, 2 Replies
Hi I'm sending a model from revit to robot (2014). I wanted to check if everything is fine at this stage before continuing further. But when I mesh the robot model with rectangular preferences it generates unwanted circular patterns at the foundation level. Robot file is attached; can you help me finding out the reason behind this and suggest a solution. Thanks in advance.
Serhan BAKIR
http://www.stand.com.tr/
Tags (1)
2 REPLIES 2
Artur.Kosakowski
in reply to: SerhanB
I deleted the mesh from this panel, changed the mesh parameters and launched local mesh generation.
Artur Kosakowski
SerhanB
in reply to: Artur.Kosakowski
thanks for your fast response and solution !
Serhan BAKIR
