Discussion Groups
Robot Structural Analysis
Active Member
SICAD
Unidirectional release
346 Views, 5 Replies
02-20-2012 04:13 AM
what I'd like to know is:
does "Released direction" mean that there is no restraint in that direction?
For example, does released direction Ux+ mean "no restraint in Ux+"?
In the attached sketch you can see my doubt.
Thank you.
Please use plain text.
Product Support
Rafal.Gaweda
Re: Unidirectional release
02-20-2012 04:40 AM in reply to: SICAD
Take a look at this help topic:
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-A65C66FB-20DA-4B7C-BFE2-3A7B0CF54F7-249.htm
UX+\- shows different direction depending on bar start \ end
Rafal Gaweda
Active Member
SICAD
02-20-2012 05:29 AM in reply to: SICAD
Oh, yes! ... But I think that it is exactly the opposite!
Product Support
Rafal.Gaweda
02-20-2012 06:14 AM in reply to: SICAD
Take a look below, no compression (yellow diagram , Fx force) on right hand side beam due to release Ux+ defined at the beginning of this bar, tension in left bar
Rafal Gaweda
Active Member
SICAD
02-24-2012 12:52 AM in reply to: Rafal.Gaweda
I think the problem is solved:
let's take a look to the central node; the situation should be
this means that the 1st node of the 2nd bar is free in Ux+, while the whole bar is free in Ux-.
Due to the fact that there is a DSC element (is it correct?), the node and the bar move in opposite directions.
So the "beginning node of the bar element" (User's guide) is the node 1 of my sketch, while I intended that it was the "new node" of my sketch (they can move in opposite directions).
Giorgio
Product Support
Rafal.Gaweda
02-24-2012 04:11 AM in reply to: SICAD
DSC algorithm creates connections between phisical node (on your screen capture node 1, on mine (below) node 2) and calculation node (on your screen capture "new node", on mine  - node 10).
In our situation (unidirectional realease UX+) such link does not exist between these two nodes only in UX+ direction so node 1 (or 2 on my example) can be displaced but your "new node" (mine node 10) remains in the same position.
In case of opposite direction force these nodes will act toghether:
Rafal Gaweda
