Hi!
I'm now learning robot, and I would like to know how i can model an uni-directional slab (i want it only to work in x direction for example), when you define a slab in RSA, firstly it always is defined as a bi-directional slab.
(imagine that you have beams in 1 direction, you draw a slab inside of them, and you want to simulate it).
In other words, i have this :
and i would like to have only the blue one.
Thank you very much for your help!
I've tried to figure out this problem searching on the help but I can't find the solution explicitly.
Check this thread:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/hollow-core-slab/td-p/3949576
There is another way to define a uni directional slab without modify the "n" parameter?
I saw a example of the kind of slab i want to model in another thread:
http://forums.autodesk.com/autodesk/attachments/autodesk/351/14461/1/Section.png
There, the slab works only in one direction...
RSA has to have an easier way to do it? A simple checkbox for example?
I don't know if im explaining clearly what i have to do...
(as you can see, in the other thread he slab only have a direction of work between beams)
Thank you very much!
IN the thraed I mentioned you have:
- checkbox
or
- n parameter
if you are not concerned about results in slab just use diphragm with unidirectional load distribution.
