Hello.
Using RSA Pro 2010 (educational)
I am modeling a simple space frame for rough analysis purposes.
I am unable to 'verify' any of the members used.
I cannot populate the Member Verification field in the Calculations box accessed under the Steel/Aluminum Design menu item.
Initial member sizing has been made. Results received earlier seemed reasonable. Load combinations were manual, though the Code setting is Eurocode.
When I go to the List button, beside the Member Verification field, on the Calculations box, the Member Selection box appears as expected. I attempt to populate the member selection field above the Previous button, which shows an appropriate range of bars. However, when I Close the Member Selection box, the selection does not transfer into the Member Verification field within the Calculations Box - it remains blank. Attempting to do Calculations fails with an error message indicating an Error in the Member List. There is no other error message or other guidance.
I realise that there may be several possibly problems - many of a general nature, but perhaps a short list of possibilities will get me started in the right direction.
Thanks, Jeremy UK
Not having the file I can only guess but most likely either the member types are not assigned to bars or these types do not match with the selected design code. Please try to crate a new label and assign it to all bars. I assume that then you will be able to run the code checking.
