When creating a spring nodal support the support label appears on every other tabs (linear and planar).
Should this be happening?
When I check the support table I can't see a distintion between nodal, linear and planar supports and their respective units. How can I control the type of supports used on the model?
Solved by Pawel.Pulak. Go to Solution.
You may create different labels (support names) for nodal, linear and planar supports.
Some additional info related to:
See this video (with additional audio explanations and comments):
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
Here is an example of the problem I've found.
Consider a concrete slab model with 10x10x2.5m supported on 4 sides.
I've created 3 different models:
On the left with nodal spring supports of kz=100 MN/m each.
On the midle with linear spring supports of kz=100 MN/m/m each.
On the right with nodal spring supports of kz=100 MN/m applied as linear on the edges (wich can happen by mistake because the program allows it). These changes the reactions bescause, I think, Robot considers twice the stiffness on the corners between edges.
The question is, should Robot allow to assign nodal springs as linear springs (by mistake)?
This comes along with the fact that, besides label, it seems to be no other way of controling if a support is nodal, linear or planar.
Is this what is happening?
In both models with supports applied to edges (the model in the middle and on the right) the stiffness in corner nodes is obtained by adding the stiffnes corresponding to both edges meeting in this corner but
1/ for the model in the middle the tributary length for corner nodes is half of the tributary length for internal nodes so the sum results in the correct value
2/ for the model on the right the stiffness is the same in all nodes so the sum in corner nodes results in doubled stiffness
It can be checked whether the correct support label is assigned to edges verifying whether "Constant elastic coef. at support nodes" check-box is not active in the definition of the label. I have shown and discussed it in the video linked in my previous post.
The improvement request was registered to report verification warning when nodal elastic supports are assigned to edges, panels or faces.
