I keep getting an instability in the Rx direction in one or 2 nodes, I can't work out why as the releases and member sizes etc should be the same as adjacent corresponding nodes. Would you be able to take a look? Any advice would be appreciated.
Kind regards,
Georgina
Solved by Rafal.Gaweda. Go to Solution.
Check \ set correct releases in your model.
I have created new dummy case with the loads as shown below. Results in table.
It means you have to correct model \ releases in it.
