Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Type 1 instability
5 REPLIES 5
SteveG021
7096 Views, 5 Replies
Type 1 instability
Hi Rafael,
I have desinged a simple truss walkway but am getting type 1 instabilities in the pin supports in all directions (RX, RY, RZ).
The member utilization ratios are very small, but i cant seem to correct the errors unless i place bracing at the base of the supports.
Is there a solution without over designing the structure?
I have attached the model for your use.
Regards
Steve
Tags (1)
5 REPLIES 5
Rafal.Gaweda
in reply to: SteveG021
I think the releases on all columns should be defined as shown below:
Rafal Gaweda
SteveG021
Hi Rafael,
HOw come you have the Ry fixed for the right sided columns and free for the near side coloumns?
Would this also not create a moment in the pin connection? We are trying to avaoid that.
Steve
Rafal.Gaweda
Steve
Check results ; releases on beams do that
Check results  - see below
Rafal Gaweda
SteveG021
in reply to: Rafal.Gaweda
Hi Rafal,
I seemed to have solved the problem and was running the analysis error free.
I then made some adjustements to the type of bars< assigning columns, beams and bars, all of which have the same properties.
Please see the attachement to see the latest error.
Steve
Rafal.Gaweda
Correct defintion of Pinned-Pinned support below:
Rafal Gaweda
