I have a project in school where i have to analyze a 2 story building with a slab deck on the roof. Columns are a-symetrical and part of the slab on the 2nd floor is a cantilever slab on one edge [the edge with a radius 😞 ]. The slabs will be Flat Slabs, no perimeter beams, and the thickness has been labeld 12" by the architect. I have used Robot briefly in the past for steel frame analysis, but before I dig into it I would like to make sure Robot is my best bet for something like this. Would you all recommend it? I have been told of other softwares, but i am comfortable using autodesk interface so I would really like to make sure I would be heading in the right direction in approaching Robot for the analysis.
Ved
To help you with your choice : http://www.robotoffice.com/rsa/ - plate movie, RC Structures movies
http://www.robotoffice.com/rsa/hrh_flm/044_films_robot.htm#
ot should look like that. If not please check your firewall \ web browser : blocking of streamings, swf-s etc
You can see the real case design of such slabs in this therad http://forums.autodesk.com/t5/Autodesk-Robot-Structural/RC-Slab-provided-reinforcement-not-calculati...
Not Found
The requested URL /rsa/hrh_flm/044_films_robot.htm was not found on this server.
another link please ^_^
Khaled_Elbanna
Not Found
It works:
