Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Mirko.Jurcevic
254 Views, 5 Replies
two strange bugs
today I've discovered two strange bugs in my model.
First of all, if I type for panel thickness name something with a dot, it gives me an error "no material" and panel thickness cannot be displayed.
For example: "Z.20cm" name doesn't work correctly.
Second, I am attaching my model where I've got rounded mesh around my wall with mesh on that wall itself. Why, I don't know. All I did was that I pushed "Mesh generation" magic wand.
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
5 REPLIES 5
Hi Mirko,
For the Round panel
There´s a panel ,nr 50 , with this wrong contour.
For the thickness name , I created the Z.20cm thickness and assigned all the panels with it. No problems here.
I didn´t understand why " kinematic constraints" was ON and also that large opening with th same size of the horizontal slab. This model came from Revit?
Rafael Medeiros
I see this:
Rafal Gaweda
Actually, after some testing, dot is not the problem.
Problem is in changing the name of panel thickness.
Look what happens, panels are loosing thickness (they remain asociated with unexisting thickness): http://screencast.com/t/pybBCT0q
Is this normal behaviour?
Mirko Jurcevic
Thank you guy for cheking out my model.
" For the thickness name , I created the Z.20cm thickness and assigned all the panels with it. No problems here.
I didn´t understand why " kinematic constraints" was ON and also that large opening with th same size of the horizontal slab. This model came from Revit? "
It's a student model from today's education. It didn't came from Revit.
Yes, that's the problem, I didn't notice that extra panel n.50 (obviously wrong). Great job, thanks!  🙂
Mirko Jurcevic
Do not make it this way.
Rafal Gaweda
