Discussion Groups
Robot Structural Analysis
andrea.pontiggia
Two problems
227 Views, 4 Replies
09-22-2012 01:28 AM
Hello, I have two problems:
-as I can orient the reference system more panels in the same direction automatically?
-in a model I find this problem, but I can not figure out where the model is wrong?
(i attach the file)
Cattura.JPGCatra.JPGthanks
Andrea
Please use plain text.
*Expert Elite* | International Moderator
Romanich
Re: Two problems
09-22-2012 02:11 AM in reply to: andrea.pontiggia
answer for your first question is Yes.
Product Support
Rafal.Gaweda
Re: Two problems
09-24-2012 01:36 AM in reply to: andrea.pontiggia
I will check the model but take a look at this thread http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Error-Nr-100/m-p/3602456/highlight/true#M713...
Rafal Gaweda
Product Support
Rafal.Gaweda
Re: Two problems
09-24-2012 01:51 AM in reply to: Rafal.Gaweda
It is caused by not connected rigid link and some nodes not connected to bars located on claddings egdes \ corners.
Corrected file attached.
Rafal Gaweda
andrea.pontiggia
Re: Two problems
09-24-2012 08:08 AM in reply to: Rafal.Gaweda
thank you very much
Andrea
