What are the risks associated with having two or more robot models open in the same PC?
I've noticed that using the add-ins available here in the forums can be confusing when two models are open. Also, how is access to the results files occuring?
It would be helpful if some list of things to be warned about while working on two (or more) models can be had to refered to.
Rico
Solved by Rafal.Gaweda. Go to Solution.
No risks except using API.
Not possible to control this.
Using API addins \ macros only one Robot must be used.
