Solved by jad.dellel. Go to Solution.
You can download a training manual from the link below:
http://images.autodesk.com/adsk/files/robot_2010_training_manual_metric.pdf
Best regards,
see on youtube:
http://www.youtube.com/results?search_query=robot+structural+analysis&aq=7
I guess this topic should be usefull :
I strongly recomend watch tips and tricks from Autodesk web site. There are very good videos about Robot, Revit and Robot integration. See attached link about Robot: http://www.aec-projects.com/tips-and-tricks/structure/robot-features/
Gustavo
I do not think that Autodesk Robot ...... will be a most used program because it does not has tutorials from the autodesk company stie like other programs.
I'm searching for video tutorial robot structrual analysis
"" http://ebookee.org/Autodesk-Robot-Structural-Analysis-Video-tutorial-2011_1025342.html ""
who have movie this tutorial send me the link???
Thank all
Hello All,
There have been many requests for documentation on Robot Structural Analysis. There is a new book recently published called Autodesk Robot Structural Analysis 2013 - Essentials which is available here: http://tiny.cc/RobotEssentialsa
I hope you find it helpful in learning Robot Structural Analysis Pro.
-Ken
For all who are working on Autodesk Building Design Suite 2014, a new version of Autodesk Robot Structural Analysis Professional - Essentials is available now!
We've received some really great feedback from beginners and experienced users alike. Users at all levels are finding this to be valuable information to add to their understanding of the program. Check it out here: http://tiny.cc/ARSAP2014_Book
Don't leave this powerful analysis and design tool on your shelf.
Thanks Ken
I like BIM of autodesk, But with autodesk softwares when you design steel conection in robot, then not link it to autocad structural detailing or revit structure
can you help me for this workflow when use revit structure, robot and autocad structural detailing
thanks
there's an integration between Revit and Robot & integration between Revit and ASD
and you can use Revit to link between Robot to/from ASD
Hi @Anonymous. Can you post step by step video/images for robot to revit and revit to robot integration if poosible. It will be really useful for many people.
Also kindly let us know for transfer of reinforcements too.
Regards
is there any latest pdf tutorial for Autodesk Robot Structural Analysis? thanks
