Discussion Groups
Robot Structural Analysis
Product Support
pp2008
Re: tutorial or example for machine foundation
07-24-2012 04:59 AM in reply to: alb2
What to you mean by transient response? When changing the frequency of excitation?
In such case time history analysis should be used.
FRF analysis is analogous to harmonic analysis with only such difference that instead of one frequency it is performed for series of different frequencies and it gives additional possibilities of output (like diagrams of results in function of frequency) - but both are related to steady-state harmonic vibrations
Best regards,
Pawel Pulak
Please use plain text.
Active Contributor
alb2
07-24-2012 05:21 AM in reply to: pp2008
Yes, by transient response, i meant the block response when the machine changes its frequency from start to operational frequency considering damping.
I want to plot the chart - response amplitude of a point of the machine/ frequency from 0-50 HZ lets say. as in the picture
Which analisys is suitable? And since in theory, applying the dynamic forces in the centre of concrete base or applying them with rigid link on top of foundation, doesnt make big difference.Does it concern the calculations in RSA??
Product Support
pp2008
07-24-2012 06:03 AM in reply to: alb2
In such case time history analysis will be necessary - as in this forum topic:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Time-History-Analysis-for-a-rotating-motor/m...
Moreover instead of constant frequency of forcing function the variable frequency will be necessary - more sophisticated forcing function.
Time history analysis will not give you directly the diagram in the function of frequency - only diagrams in the function of time are available in it. So it will be necessary to export some data to for instance MS Excel and generate diagrams there.
As concerns the influence of the point of application of dynamic loads (centre of concrete base or centre of mass of rotating part of the machine) it depends whether the distance between these points is significant or not.
Best regards,
Pawel Pulak
Active Contributor
alb2
07-24-2012 06:06 AM in reply to: pp2008
Thank you.
Active Contributor
alb2
07-27-2012 05:23 AM in reply to: alb2
i have a rigid link with one master node and 4 slave nodes, i want to design another rigid link with a different master node and 4 slave nodes, where 2 of these slave nodes are also slave nodes from the 1st rigid link.as in the picture.
is there a problem regarding this or is just a graphical issue?
Can this be done selecting 2 nodes as master and the others as slaves? It seems like NOT to me.
Product Support
pp2008
07-27-2012 06:05 AM in reply to: alb2
as it is written in Help: "A node can be defined as a slave node only in one rigid link."
If these 2 rigid links you mentioned are in reality one rigid body then I recommend defining it as one rigid link. I such case  the master node of one or rigid links will change into slave node.
If these are in reality 2 separate different bodies then I recommend:
1/ or using finer mesh to use separete slave nodes for them
2/ or replacing rigid links with very rigid bars (in such case necessary to define material or loads and load to mass conversion in such way that mass of these bars will not be taken into account)
Pawel Pulak
Active Contributor
alb2
07-27-2012 06:32 AM in reply to: pp2008
I like the second option better,
so in this case Im defining a new material with high modulus of elasticity. Applying the new material to the bars that will connect the mass ( which will be substituted by force) to the bearing points. Is this correct?
Product Support
pp2008
07-27-2012 06:49 AM in reply to: alb2
It cab be even standard Young's modulus of steel (providing section properties are big). What is important is zero unit weight (density) of the new material - to avoid considering it in selfweight and vibrations.
Pawel Pulak
