I have tried to design the truss K joint with a gap and it seems that the software does not perform the check according to EN 1993-1-8 5.1.5 (5.1 a and b). So, therefore now it is possible to design a K joint detail with a gap of 1000000mm 😉 without taking into account such huge eccentricities unless it is down to the designer. I think the check should be incorporated.
Best regards,
Solved by Artur.Kosakowski. Go to Solution.
I'll check this next week but could you attach a sample connection of the type you described please? This will help me a bit. Thank you.
Thank you. After checking I can see that internally (in the Robot internal code) such check is actually done but by mistake the corresponding error about the incorrect geometry of a connection is not displayed. This is now in the hands of the development team.
Corrected in SP3 for Robot 2015.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
