Discussion Groups
Robot Structural Analysis
dan.suciu
Truss insertion error
414 Views, 10 Replies
03-02-2012 06:30 AM
I am trying to insert a truss element from the library, but as soon as I finish editing the parameters,
and click apply,ok  , it gives me an error(this is valid for all library elements)
I have tried going in different project types to see if this is the problem , but same error appears.
i have attached the error mesage,\
the error is :
Syntax incorect:line ignored
(2*%NF-1) %DIAGS "gamma" %DIAGSgamma
thanks in advance,
Dan,Suciu
Please use plain text.
Product Support
Artur.Kosakowski
Re: Truss insertion error
03-02-2012 06:40 AM in reply to: dan.suciu
What language do you work with in Robot and what are the material and steel section databases declared in Job Preferences?
Artur Kosakowski
dan.suciu
03-02-2012 06:45 AM in reply to: Artur.Kosakowski
the regional settings and printout language is Romanian, the working language is English
the material database is Eurocode with S460M M/L
the steel section database is ROMAN (for romanian steel products)
Product Support
Artur.Kosakowski
03-02-2012 07:08 AM in reply to: dan.suciu
The library structures are based on the text files which are language dependent. For Romanian regional settings they have French name for steel (Acier) material assigned which doesn't exist in the Eurocode material database. Please add it  in the way shown on the attached picture. Of course you should change the material of bars to the intended one after inserting the truss.
Artur Kosakowski
dan.suciu
03-02-2012 07:29 AM in reply to: Artur.Kosakowski
thank you,
this has solved the problem
Member
wadii.bouzemmi
08-07-2012 08:04 AM in reply to: Artur.Kosakowski
ROBOT97 Triangular Truss Type 1
TRU PLA
VER NON
VAR
SECTION "Dimensions" "d_tria1"
  %UP = [BOOL] ?"0" : *First Diagonal Up
  %SLL=]0.0,100000.0,ULENGTH] ?"30.0" : *Length L:
  %SH=]0.0,100000.0,ULENGTH] ?"6.0"   : *Height H:
  %NF=[4,50] ?"6" : *Number of Fields:
  %MEMB=[BOOL] ?"1" : *Continuous chord
  %REL=[BOOL] ?"1" : *Moments Released
SECTION "More..." "d_tria1a"
  %DIS=[0.0,1000.0,ULENGTH] ?"0.0"    :*Distance D:
  %DID=[0.0,1000.0,ULENGTH] ?"0.0"    :*Distance D1:
SECTION "Sections" "d_tria1"
  %CHORU= [profil]?"WT 12x52"               : *Upper Chord -
  %CHORUgamma= ?"0"                         : * - gamma angle =
  %CHORL= [profil]?"WT 12x42"               : *Lower Chord -
  %CHORLgamma= ?"180"                       : * - gamma angle =
  %DIAGS= [profil]?"DL 2x2x0.25"            : *Diagonals -
  %DIAGSgamma= ?"0"                         : * - gamma angle =
  %POSTS= [profil]?"DL 2.5x2.5x0.25"        : *Posts -
  %POSTSgamma= ?"0"                         : * - gamma angle =
VAR END
NUM DIS
UNITS
Len=ft Force=kip
NOD
1 0 0
#if %DIS = 0.0
1 tra x=(%SLL/%NF) 2 G (%NF)
(%NF+2)r((%NF+4)/2-3) (%SLL/%NF) (2*%SH/%NF)  (%SLL/2) (%SH)
(%NF+2+%NF/2)r((%NF+4)/2-4) (%SLL/2+%SLL/%NF) (%SH-2*%SH/%NF) (%SLL-%SLL/%NF) (2*%SH/%NF)
#else
1 tra x=(%SLL/%NF) z=(%DIS/%NF) 2 G (%NF)
(%NF+2)r((%NF+4)/2-3) (%SLL/%NF) (2*%SH/%NF+(%DIS/%NF))  (%SLL/2) (%SH+(%DIS/2))
(%NF+2+%NF/2)r((%NF+4)/2-4) (%SLL/2+%SLL/%NF) (%SH+(%DIS/2)-2*%SH/%NF+(%DIS/%NF)) (%SLL-%SLL/%NF) (2*%SH/%NF+%DIS-(%DIS/%NF))
#endif
#if %DID > 0.0
1 tra x=(%SLL/%NF) z=(%DIS/%NF+(2*%DID/%NF)) 2 G (%NF/2)
(%NF/2+1) tra x=(%SLL/%NF) z=(%DIS/%NF-(2*%DID/%NF)) (%NF/2+2) G (%NF/2)
#endif
ELE
#if %MEMB = 0
1r(%NF-1) 1 2
(%NF+1) 1 (%NF+2)
(%NF+2)r(%NF-3) (%NF+2) (%NF+3)
(2*%NF) (2*%NF) (%NF+1)
#if %UP = 1
 (2*%NF+1)r(%NF/2-2) 2 (%NF+3)
 (2*%NF+%NF/2)r(%NF/2-2) (%NF)by-1 (2*%NF-1)by-1
#else
 (2*%NF+1)r(%NF/2-2) 3 (%NF+2)
 (2*%NF+%NF/2)r(%NF/2-2) (%NF-1)by-1 (2*%NF)by-1
#endif
(3*%NF+1)r(%NF-2) 2 (%NF+2)
#else
    #if %DID=0
     1 1 (%NF+1)
     2 1 (3*%NF/2+1)
     3 (%NF+1) (3*%NF/2+1)
    #else
     1 1 (%NF/2+1)
     2 (%NF/2+1) (%NF+1)
     3 1 (3*%NF/2+1)
     4 (%NF+1) (3*%NF/2+1)
    #endif
     #if %UP = 1
      100r(%NF/2-2) 2 (%NF+3)
      (100+%NF/2-1)r(%NF/2-2) (%NF)by-1 (2*%NF-1)by-1
     #else
      100r(%NF/2-2) 3 (%NF+2)
      (100+%NF/2-1)r(%NF/2-2) (%NF-1)by-1 (2*%NF)by-1
     #endif
     200r(%NF-2) 2 (%NF+2)
#endif
PRO
STEEL
#if %MEMB = 0
 1to(%NF)                  %CHORL "gamma" %CHORLgamma
 (%NF+1)                   %CHORU "gamma" %CHORUgamma
 (%NF+2)to(2*%NF-1)        %CHORU "gamma" %CHORUgamma
 (2*%NF)                   %CHORU "gamma" %CHORUgamma
 (2*%NF+1)to(5*%NF/2-1)    %DIAGS "gamma" %DIAGSgamma
 (2*%NF+%NF/2)to(3*%NF-2)  %DIAGS "gamma" %DIAGSgamma
 (3*%NF+1)to(4*%NF-1)      %POSTS "gamma" %POSTSgamma
#else
    #if %DID=0
     1 %CHORL "gamma" %CHORLgamma
     2 3 %CHORU "gamma" %CHORUgamma
    #else
     1 2 %CHORL "gamma" %CHORLgamma
     3 4 %CHORU "gamma" %CHORUgamma
    #endif
     #if %UP = 1
      100to(100+%NF-3) %DIAGS "gamma" %DIAGSgamma
     #else
     #endif
     200to(200+%NF-2) %POSTS "gamma" %POSTSgamma
#endif
  REL
#if %REL = 1
#if %MEMB = 0
   ELE 1to(%NF)                  ORI ry  END ry
   ELE (%NF+1)                   ORI ry  END ry
   ELE (%NF+2)to(2*%NF-1)        ORI ry  END ry
   ELE (2*%NF)                   ORI ry  END ry
   ELE (2*%NF+1)to(5*%NF/2-1)    ORI ry  END ry
   ELE (2*%NF+%NF/2)to(3*%NF-2)  ORI ry  END ry
   ELE (3*%NF+1)to(4*%NF-1)      ORI ry  END ry
#else
    #if %DID=0
     ELE 1 ORI ry  END ry
     ELE 2 3 ORI ry  END ry
    #else
     ELE 1 2 ORI ry  END ry
     ELE 3 4 ORI ry  END ry
    #endif
     #if %UP = 1
      ELE 100to(100+%NF-3) ORI ry  END ry
     #else
     #endif
     ELE 200to(200+%NF-2) ORI ry  END ry
#endif
#endif
  SUP
END
SUP
1 (%NF+1)
LOA
CASE # 1
(%NF+2)to(2*%NF) Fz=-1.0
END
Member
edyez
02-13-2013 11:26 AM in reply to: dan.suciu
salut aceeasi problema am si eu .....zi mi exact te rog **** ai facut ...am incercat sa aplic ce am vazut in imaginea aceea atasata si tot nu a mers ! ms fain
Member
edyez
02-13-2013 11:48 AM in reply to: Artur.Kosakowski
i have done what you say , and it doesn`t work ... pls give me details ... greetings !
Product Support
Artur.Kosakowski
02-14-2013 12:11 AM in reply to: edyez
Could you give me the answers on the questions from the message 2?
Artur Kosakowski
Member
edyez
02-14-2013 12:58 AM in reply to: dan.suciu
I set all over the Romanian language ! and the second problem : i can` t set up ASD in Preferences (there is ASD and ROBOT - with robot checked). thanks
