Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Truss frame inquiry
2 REPLIES 2
dan.suciu
349 Views, 2 Replies
Truss frame inquiry
hi,
I am building a frame with 5 bays and 6 oppenings which has a truss roof system.
I have introduced the trusses using the library option, and edited them to my conformation.
I think i am doing something wrong, because when i load the truss element I get relatively large bending moments in the bars, also in nodes, ... and what i thing is a big axial force .
My question is if i need to set some releases for the bars, or if the current approach is the correct one.
The project is for my bachelors degree.
I have attached the project file bellow,loaded on 2 frames(just for test pupose)
Thank you in advance,
Dan,Suciu
2 REPLIES 2
tony.ridley
in reply to: dan.suciu
At the moment you have a kind of portal action happening (ie trusses are transferring moment into the columns).
Attached is file with truss ends pinned.
I only pinned trusses in the X direction.  You need to go through and do the ones in the Y direction too.
Tony
dan.suciu
in reply to: tony.ridley
I think this was the solution,
thank you tony
