Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
truss design
17 REPLIES 17
Message 1 of 18
CKDDIZ
5760 Views, 17 Replies
truss design
hello,
my question is related to truss design,when the moment release is applied to the truss member during calculations the instability window appears!!! Why does this happen?
17 REPLIES 17
Message 2 of 18
Rafacascudo
in reply to: CKDDIZ
You shouldn´t apply releases to the members that have a pinned support as one of their nodes.
Also ,Instead of using releases you can use "truss bars  only" through geometry/additonal atributes/advanced properties
Rafael Medeiros
Message 3 of 18
CKDDIZ
in reply to: Rafacascudo
I tryed to model an example from the truss database selection on two fixed columns, the truss members are moment realesed from the truss table option.
Still got the stability window during calcs!!
Message 4 of 18
Artur.Kosakowski
in reply to: CKDDIZ
Delete the side posts and replace them with the columns.
Artur Kosakowski
Message 5 of 18
CKDDIZ
in reply to: Artur.Kosakowski
calculated a truss in 2D in truss structure type (pic 1), exporting it in 3D ( pic 2) getting instability in Y dir.
Suggestions please!
Thank you
Message 6 of 18
Artur.Kosakowski
in reply to: CKDDIZ
If you have out of truss plane releases nothing prevent horizontal movement of its elements in this direction. I think you should add some boundary conditions (or redefine the releases) to prevent this from happening.
Artur Kosakowski
Message 7 of 18
CKDDIZ
1) using the truss bar option without any bar release, getting the same instability type.
2) using bar release in X,Z direction only , same instability.
Trying to solve the roof structure in 3D, how important is the bar offset of the transversal beams (purlins) in this case?
Do you recommend roof as cladding, and wind load applied on it?
Message 8 of 18
Artur.Kosakowski
in reply to: CKDDIZ
Truss bars are similar to bars with pinned end connections.
For a 3D structural roof you should keep the chords as continuous (see the attached model). Otherwise you can consider use of partial releases.
 Personally I would not define any offsets.
This is one of the options but this is going to be your decision Smiley Happy
P.S. I have corrected the error of not applying truss bar attribute to one line of posts in the attached model too.
Artur Kosakowski
Message 9 of 18
CKDDIZ
Thanks Smiley Wink
Message 10 of 18
CKDDIZ
in reply to: CKDDIZ
Is there an option in RSA, example 2 bars to be connected as 1?
Message 11 of 18
Rafal.Gaweda
in reply to: CKDDIZ
Vote here : http://forums.autodesk.com/t5/Robot-Structural-Analysis/Merging-two-bars-into-one-bar/idi-p/3701596
Rafal Gaweda
Message 12 of 18
Artur.Kosakowski
in reply to: CKDDIZ
Message 13 of 18
CKDDIZ
the first one, got the answer 🙂
thanks
Message 14 of 18
CKDDIZ
in reply to: CKDDIZ
Can you please show step by step what changes did you do to the 3d model, 😞
I see, you applied pinned-pinned releases to the purlins, what else?
The chords must be continuous or use partial releases, but I don't see in the model you applied partial releases to the chords!!
Message 15 of 18
Artur.Kosakowski
in reply to: CKDDIZ
No, actually they were already defined in the model you sent Smiley Happy
therefore I deleted truss bar attribute from them
That was just the suggestion which you can take or reject. This depends on the expected behavior of the truss node connections and  the final decision is in your hand.
Artur Kosakowski
Message 16 of 18
CKDDIZ
Smiley Embarassed got it
Message 17 of 18
CKDDIZ
in reply to: CKDDIZ
Trying to apply the wind load on a 3D model, getting the following problem
Message 18 of 18
Artur.Kosakowski
in reply to: CKDDIZ
