Discussion Groups
Robot Structural Analysis
Product Support
Rafal.Gaweda
Re: truss design
01-08-2013 06:08 AM in reply to: CKDDIZ
Is there an option in RSA, example 2 bars to be connected as 1?
Vote here : http://forums.autodesk.com/t5/Robot-Structural-Analysis/Merging-two-bars-into-one-bar/idi-p/3701596
Rafal Gaweda
Please use plain text.
Product Support
Artur.Kosakowski
Re: truss design
01-08-2013 06:21 AM in reply to: CKDDIZ
Valued Contributor
CKDDIZ
Re: truss design
01-08-2013 06:24 AM in reply to: Artur.Kosakowski
the first one, got the answer :smileyhappy:
thanks
Valued Contributor
CKDDIZ
Re: truss design
01-08-2013 06:37 AM in reply to: CKDDIZ
Can you please show step by step what changes did you do to the 3d model, :smileysad:
I see, you applied pinned-pinned releases to the purlins, what else?
The chords must be continuous or use partial releases, but I don't see in the model you applied partial releases to the chords!!
Product Support
Artur.Kosakowski
Re: truss design
01-08-2013 06:48 AM in reply to: CKDDIZ
No, actually they were already defined in the model you sent :smileyhappy:
therefore I deleted truss bar attribute from them
That was just the suggestion which you can take or reject. This depends on the expected behavior of the truss node connections and  the final decision is in your hand.
Artur Kosakowski
Valued Contributor
CKDDIZ
Re: truss design
01-08-2013 06:52 AM in reply to: Artur.Kosakowski
:smileyembarrassed: got it
Valued Contributor
CKDDIZ
Re: truss design
01-10-2013 02:03 AM in reply to: CKDDIZ
Trying to apply the wind load on a 3D model, getting the following problem
Product Support
Artur.Kosakowski
Re: truss design
01-10-2013 02:10 AM in reply to: CKDDIZ
