Trapezoidal preasure load and friction loads on Silos
6 REPLIES 6
willjvizcaya
3764 Views, 6 Replies
Good Afternoon.
Ive been modeling a cilindrical Silo. wich is supposed to have 2 different kinds of loads according to ACI 313-97:
Heres is a description of what im intending to do.
1. Blue Load: is a Frictional Load, wich goes increasing according to the Silo Depth.
2.Yellow Load: A linear Load on surface, wich increases for the Ganmma * Height like hidrostatic Load.
I tried to assign de 2nd case as a hidrostatic preassure load, with the boundaries of 8meters (top of material). for this case, i have no idea what the program is assigning, as for the 1st case, i couldnt find a load type that fits my needs.
What do you suggest?.
6 REPLIES 6
See the attached pictures.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Dear Artur, Could you explain how to select the right A, B, C points to apply that frictional load? Thanks,
Technical Specialist
Nexsys de Colombia
E.g.
A: on the axis of the silo with Z being the coordinate where the load 'starts' (e.g. 0,0,10)
B and C: symmetrical on 'both' sides of this axis at the point where you know the value of load (e.g. -4, 0, 0 and 4,0,0)
Artur Kosakowski
willjvizcaya
in reply to: willjvizcaya
good morning Artur.
I have the same problem, cant find how to make tha A, B, C definition, is there any chance you could make it graphically?
Thx.
Artur Kosakowski
Jorge could you kindly explain how you created the junction skirt between the cylindrical part of the silo and the hopper? How did you create the hopper with the bottom closed?
Regards
Ishmael
