Discussion Groups
Robot Structural Analysis
Active Contributor
vmorkunas
Transparent areas in the panel
178 Views, 2 Replies
01-10-2013 01:02 AM
Dear support,
I am having problems with panels' graphical representation. I have drawn part of one panel on top of another and later deleted one which was overlaped. Now I see the area where deleted panel used to be as a transparent area in a panel. It is meshed corectly and gives me all results, its just the look of it which is bad (especially in a report). I've tried to play with graphical acceleration settings and run computational model, but it did not help. Are there any tips? see screenshot attached
Thank you
Please use plain text.
Product Support
Artur.Kosakowski
Re: Transparent areas in the panel
01-10-2013 01:27 AM in reply to: vmorkunas
Try to make a copy of the file and open it in the repair mode.
Artur Kosakowski
Active Contributor
vmorkunas
01-10-2013 04:04 AM in reply to: Artur.Kosakowski
Thanks, this worked after opening it in a repair mode and runing cumputational model again.
