Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Transparent areas in the panel
2 REPLIES 2
vmorkunas
408 Views, 2 Replies
Dear support,
I am having problems with panels' graphical representation. I have drawn part of one panel on top of another and later deleted one which was overlaped. Now I see the area where deleted panel used to be as a transparent area in a panel. It is meshed corectly and gives me all results, its just the look of it which is bad (especially in a report). I've tried to play with graphical acceleration settings and run computational model, but it did not help. Are there any tips? see screenshot attached
Thank you
2 REPLIES 2
Try to make a copy of the file and open it in the repair mode.
Artur Kosakowski
Thanks, this worked after opening it in a repair mode and runing cumputational model again.
