Translating Robot
20 REPLIES 20
Message 1 of 21
Mirko.Jurcevic
1214 Views, 20 Replies
Translating Robot
Hi!
I want to know is there a way to:
- add new language to Robot UI
- translate some parts of Robot / if not the whole
- most important, is there a way to translate reports, for example results of steel connections calculations etc.
Is it possible through API, or by changing some files? Any way would be helpful. I searched a lot, on web and offline (Robot files) - no luck
"Language packs" - who's making them, Autodesk or anyone who's capable?
I need to get Robot to "speak" Croatian.
In general, authorities for building permits here in Croatia do not accept documentation in foreign languages (ex. English etc) so this is a must for us.
Please help!
Best regards,
Mirko
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
20 REPLIES 20
Message 2 of 21
This is Autodesk job. The only part from the items you mentioned that I can think is possible for you to edit is the steel design note. To do so e.g. for EC3 you should modify de32.rtf file from Templates sub folder of Robot.
Mind that you should use WordPad rather than Word. You will need to replace variable with Croatian words e.g.
@variable@ with Sampletext
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 21
Thank you mr. Kosakowski!
Mirko Jurcevic
Message 4 of 21
Hi Artur!
Here I am again on the same task mentioned above.
I've tried changing some @variable@ with SampleText, but that's "Sisyphean task".
First of all, I don't know which template belong to which calculation report, I don't see logic in template naming.
Then, there are countless variables to replace in one template file, and if I change, for example:
@ST_RC_CALC_CODE@ variable in one file, I have to do it again and again in all of the other template files.
Isn't there a better way to do this? Some xml to translate or adjust, creating API, anything...
Any suggestion will be helpful.
Calculation reports are structural engineer's final product, they must be usable.
Mirko Jurcevic
Message 5 of 21
If it was I'd have suggested it Smiley Sad
Artur Kosakowski
Message 6 of 21
OK, that's not good news.
I am using pure Eurocode, is there a way to filter those template files to those which corresponds to Eurocode? So I can at least save some time in research.
Mirko Jurcevic
Message 7 of 21
Concrete:
bven_.rtf – RC Walls
bsen_.rtf – RC Slabs
bmen_.rtf – RC Beams
bjen_.rtf – RC Joints
bfen_.rtf – RC Foundations
bf_R_en_.rtf – RC Foundations reinforcement
bf_G_en_.rtf – RC Foundations soiils
bcen_.rtf – RC Columns
De32.rtf - EC3
Artur Kosakowski
Message 8 of 21
Thank you Artur, very kind of you.
You saved me days of research!  🙂
Mirko Jurcevic
Message 9 of 21
duchoabn
in reply to: Mirko.Jurcevic
Dear all
I have a problem with edit beam note
please see picture below
Message 10 of 21
Mirko.Jurcevic
in reply to: duchoabn
Why do you "Save As..." directly to Robot's System/Template folder?
Why don't you save it somewhere else (on Desktop maybe 😉  ) and than copy/paste it in Robot's System/Template folder?
That's how I do it, and it works for me.
Don't forget to save backup copies of Robot's original template files.
Mirko Jurcevic
Message 11 of 21
duchoabn
Yes Thanks you very much
I want to ask a question
WHen I design a beam as method use RC Element design  THEN Beam note will use file name.....rtf??>
thanks pro
Message 12 of 21
Mirko.Jurcevic
bmen_.rtf  ?
I assume you use Eurocode (EN 1992-1-1)
Mirko Jurcevic
Message 13 of 21
duchoabn
thanks you very much
I am understand, But i can't edit please help me as a video tutorial to edit?
thanks pro
Message 14 of 21
Mirko.Jurcevic
I am afraid that I will not manage to do that today. I still have a lot of work to do.
Maybe next week.
Mirko Jurcevic
Message 15 of 21
duchoabn
thanks pro
I very much
can you send for me a document practice rsap
thanks pro
Message 16 of 21
duchoabn
Dear pro
Can you help me for this prolem?
Message 17 of 21
Mirko.Jurcevic
I will create you a video in a few minutes.
Mirko Jurcevic
Message 18 of 21
Hey Mirko is this video still available?
Message 19 of 21
uh, that was years ago, I don't really remember what video I was talking about.  😄
Let me guess, I think this is what you are looking for:
https://www.youtube.com/watch?v=H4ynBPYpJWQ
It's showing the app I developed while working in Intelika Ltd. (www.intelika.hr), it translates Robot .rtf and .docx calculations reports from English into Croatian.
Mirko Jurcevic
Message 20 of 21
Mirko thanks for the quick reply!
This application looks great and it's just what I need and I've sent them an email to see is there any way to get it, but the video I'm interested in is more you showing how to edit the existing Robot template to display croatian names for report components.
Pozz
