Transferring Generic Models from Revit to Robot
16 REPLIES 16
Message 1 of 17
hms3
1915 Views, 16 Replies
I have little over four months of experience in Revit and I'm currently working on a dam project which requires me to use very specific types of wall profiles. These are thick concrete blocks which I created with generic models. Regular walls are used to support the blocks at few meters interval.
Here's the problem: If I want to export my model into Robot for structural analysis these components are missing (the walls appear fine).
Is it not possible to export Generic Models like these from Revit to Robot?
In that case any suggestions on how to get around that problem are well appreciated. Thank you in advance.
16 REPLIES 16
Message 2 of 17
Rafal.Gaweda
in reply to: hms3
Generic Models can be imported (Open \ file type *.sat) as ACIS sat files only.
Rafal Gaweda
Message 3 of 17
hms3
in reply to: Rafal.Gaweda
Thank you very much for the good tip.
Message 4 of 17
hms3
I'm having a problem when I want to assign properties to the panel that are imported to Robot like this. For example if I want to convert the panels to concrete walls with 400 mm thickness the program won't allow me.
Any ideas?
Message 5 of 17
Rafal.Gaweda
in reply to: hms3
Panel?
I guess it should be solid.
Rafal Gaweda
Message 6 of 17
hms3
All of the Structure objects in Robot are assigned as Panels.
I can assign the object as a wall and I can choose a reinforcement type, but that's all. It doesn´t assign material, thickness etc. which I would need to perform the analysis.
Message 7 of 17
hms3
This picture is probably more helpful
Message 8 of 17
Rafal.Gaweda
in reply to: hms3
Send me this file.
Rafal Gaweda
Message 9 of 17
hms3
The Robot file zipped....
Message 10 of 17
Rafal.Gaweda
in reply to: hms3
Please send me sat file.
Rafal Gaweda
Message 11 of 17
hms3
The .sat file.
Message 12 of 17
hms3
the.sat file
Message 13 of 17
Rafal.Gaweda
in reply to: hms3
Solid ACIS model example : http://wtrns.fr/A0f37Lhr3hOQFw0
Rafal Gaweda
Message 14 of 17
hms3
Thank you for your file it looks promising.
Can you please tell me how you created the volumetric objects from the solid objects that came with the sat file. I'm having trouble assigning material etc. to these solid objects.
Message 15 of 17
hms3
This is what my model looks like:
In stead of having solid objects like in your case I only have panels and I'm not able to assign any materials or other properties to these panels. Is it possible to change the panels to solid objects after the file has been opened or is this something I can change in the Robot settings for opening .sat files.
Thanks in advance
Message 16 of 17
AndyWalker
in reply to: hms3
Did you ever solve this issue?
I too am having problems in the exact same way.
How can i assign a material?
Kind regards
Andy
Message 17 of 17
Rafal.Gaweda
in reply to: AndyWalker
It may happen like this on ACIS objects. Try to replace such objects by the ones which does not have such problems.
It is registered in our database for correction.
Rafal Gaweda
