Dear Support,
I would like to know how is the expression to sum up total weight by diameter using PloEdit.
I know that to sum up by steel type is:
@elev("label","IDS_PLO_STEEL") . " " . @elev("steel_symbol","L") . " = " . @elev("steel","kg","L") . @elev("steel_unit")
but know I need by diameter.
Gustavo
Solved by Artur.Kosakowski. Go to Solution.
I'm sorry but there is no such functionality in PloEdit available. On the other hand you can easily see these values at the end of the calculation note.
Dear Gustavo,
You can easily get this table on the drawing if you open it in ASD.
