Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Total amount of rebar in the projecto
11 REPLIES 11
Message 1 of 12
gustavo_c_vasconcellos
684 Views, 11 Replies
I would like to know if it is possible to get a report with the total amount of rebar in a project.
I tried to use Quantity Survey or Cost Estimation tables, as I do for steel, but there are no summary results with rebars.
I hope that there is a better way than sum up manually the results from the drawings or from the Note's tab!
Gustavo
11 REPLIES 11
Message 2 of 12
in reply to: gustavo_c_vasconcellos
You could export to Revit and use schedule, not sure how if you don't have revit.
Tony
Message 3 of 12
No, there is no such functionality in the current version of Robot. This is what  (along with other features) the export to ASD Reinforcement is intended for.
Artur Kosakowski
Message 4 of 12
Dear Artur,
the problem with this option is that when we transfer from Robot to ASD, it doesn't transfer for just one page.
It goes to many diferent ASD page and then we have to do the summary per page and then sum up "manually" everything.
Am I right or I am doing something wrong?
Gustavo
Message 5 of 12
Thank you Tony,
I will try this option, I didn't try this before because when I export the rebar it stays "outside" the beam.
See the picture bellow
In this simple example, I model in Revit 2013, send to Robot 2013, calculate the rebar in Robot, and then update from Revit.
Artur and Tony, any suggestion how to fix the issue???!!
Message 6 of 12
Correct  unless you use Results > Structural Detailing option.
I think that this issue has already been discussed in details here: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Export-to-ASD-Reinforcement/td-p/3251346/pag...
Artur Kosakowski
Message 7 of 12
Artur,
we had discussed this issue and we asked to create a wish list including the option of exporting the elements to just one page, as requested by Dieter.
We cannot use the option Results> Structural Detailing to export many elements, because it takes a lot of time "arranging elements on the page", even using core i7 with 16MB of memory.
Maybe Tony suggestion is the best, but how can I fix the problem of the calculate rebar being outside the element in Revti?
Gustavo
Message 8 of 12
Gustavo,
Yes, we are aware of these limitations and they are under investigation.
Tony,
Could you send me the Robot file you used for export to Revit please?
Artur Kosakowski
Message 9 of 12
in reply to: Artur.Kosakowski
Sorry which file???
Message 10 of 12
Artur.Kosakowski
Tony,
I'm sorry this was intended for Gustavo as well.
Gustavo,
Could you send me the rtd file please?
Artur Kosakowski
Message 11 of 12
Artur,
I am sending attached ther rebar data base (I had to change to meet requirements) and the Robot file.
Gustavo
Message 12 of 12
Gustavo,
Please try in the first step (in Revit)  model two span beams as a single elements rather than two separate beams.
send to Robot 2013, calculate the rebar in Robot, and then update Revit from Robot.
Artur Kosakowski
