Units and values are inconsistent. For instance, elastic section modulus Wx... Wz should be listed using consistent units, moreover their values are wrong. For example HEA140 should have W.el.y=155.4cm^3 instead of 1587.3mm^2
The Elastic section moduli (Wely , Welz unit= cm3) and The shear rigidity factors (Wy,Wz unit= cm2) are different,
for the HEA 140,
Wely = 155.36 cm3
Welz = 55.62 cm3
Shear rigidity factors
Wy = 16.60 cm2
Wz = 6.55 cm2
For more details,use the section builder tool.
The section database is listing only the basic info.
Please let me know if you need more info.
