Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Time History Displacements Problem
8 REPLIES 8
Message 1 of 9
MARIOS75
529 Views, 8 Replies
Hi
I have a simple structure and I'm applying  an harmonic excitation at it's base. It's duration is 2.5sec. After that the structure oscillates freely for another 2.5secs. Results for the first part seem ok but for the free oscillation part  after the first 2.5sec it seems that the structure oscillates about a new equilibrium position.
Thank you.
Tags (1)
8 REPLIES 8
Message 2 of 9
Rafal.Gaweda
in reply to: MARIOS75
Damping not set in THA case.
Define it
Rafal Gaweda
Message 3 of 9
MARIOS75
in reply to: Rafal.Gaweda
Hi Rafal,
thanks for your reply.
I need zero damping.
So is there a restriction in analysis and I have always to set a value for damping.
Thank you.
Marios
Message 4 of 9
Rafal.Gaweda
No restrictions, just be aware of results you get
No damping -> oscillation
Your choice
Rafal Gaweda
Message 5 of 9
Rafal.Gaweda
One more thing:
your functions should end at such time step where value = 0 to avoid unnecessary oscilaltion
Rafal Gaweda
Message 6 of 9
MARIOS75
I'm not sure what do you mean.
The structure should oscillate with or without damping after the end of the harmonic load.
It's weird anyway.
Even with damping present the structure ends up again oscillating about an new equilibrium position towards the end of the response.
Thanks again.
Message 7 of 9
Rafal.Gaweda
See below
Rafal Gaweda
Message 8 of 9
Rafal.Gaweda
Because of diagrams scaling you can not see clearly oscilation diagram after 2.5s
You can export results from table to excell and generate diagram there
Rafal Gaweda
Message 9 of 9
MARIOS75
Thanks Rafal.
Closing the expression with a zero value seems to solve the equilibrium position problem but  I still I haven't been able to verifry the results for the free oscillation part.
